It is currently Thu Jul 03, 2025 1:10 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 17, 2006 10:00 pm
I chop bits out of my English Pointer's ears to make my pointing munecas.
PostPosted: Mon Sep 18, 2006 1:44 am
I bought the felt block from LMI, in the french polishing section. You can cut different shapes to suit your fancy. Worked good for me.
Horton, MI
PostPosted: Mon Sep 18, 2006 3:25 am
Last Name: Cavanaugh
City: Saint Paul
State: MN
I just scored enough linen to last me a while--my wife was throwing out an old pair of 100% linen trousers. As long as the color doesn't bleed into the shellac, I'm set.
John Cavanaugh
Saint Paul, MN
"What could possibly go wrong?"
PostPosted: Mon Sep 18, 2006 4:27 am
[QUOTE=John Cavanaugh] I just scored enough linen to last me a while--my wife was throwing out an old pair of 100% linen trousers. As long as the color doesn't bleed into the shellac, I'm set.[/QUOTE]
John one thing to look out for with colored linen other than bleeding (which is the major issue for sure) it is harder to tell when or if the outer cover is picking up oils and stain from other woods. This should only be in issue during the spit coats when it would be easy to pich up color from like rosewood and trasfer it to spruce. Just keep a close eye out.
PostPosted: Mon Sep 18, 2006 4:52 am
City: Saint Paul
State: MN
[QUOTE=MichaelP] [QUOTE=John Cavanaugh] I just scored enough linen to last me a while--my wife was throwing out an old pair of 100% linen trousers. As long as the color doesn't bleed into the shellac, I'm set.[/QUOTE]
John one thing to look out for with colored linen other than bleeding (which is the major issue for sure) it is harder to tell when or if the outer cover is picking up oils and stain from other woods. This should only be in issue during the spit coats when it would be easy to pich up color from like rosewood and trasfer it to spruce. Just keep a close eye out.[/QUOTE]
Something I hadn't thought of. Thanks.
John Cavanaugh
Saint Paul, MN
